- Aug 14, 2014
"The model improves how AI generates frames between those rendered by the GPU, which increases the frame rate and maintains image quality. In tests at 4K resolution, the updated technology raised performance from 124 FPS to 137 FPS, a gain of 10.4%. It also reduced video memory usage from 9GB to 8.6GB, which is a 4.4% decrease. These optimizations help prevent memory saturation and avoid major performance drops, especially in systems with limited video memory. As a result, users can keep their graphics settings high without compromising image quality"
www.guru3d.com
NVIDIA Will Update DLSS 3 for RTX 40 Series with Improved Frame Generation Performance
NVIDIA announced an update to the AI frame generation model used in the GeForce RTX 40 series graphics cards, which is expected to yield a performance boost of over 10%.
