Hi..
I'm having some trouble, I thought I'd try here...
Firstly, my system :
Asus A7V-E (VIA KT133).
AMD Duron [email protected] (for the moment) with proper cooling.
3D Prophet II MX @ default clock rates (for the moment) with default bios and proper cooling.
SoundBlaster Live 1024.
256mb no-name pc133.
Most recent A7V-E bios.
Detonator 12.90.
VIA 4in1 4.32
I have had most the issues people with this system are experiencing, and fixed most of them. I've had what they call the 686b bug - for the KT133, which made me unable to burn cds, copy large files, made my sb live crackle and pop and so on. I have also reinstalled Win2k using the "Standard PC" driver instead of the ACPI ones.
The only irq sharing/conflict in my box is my USB and network card - shouldn't affect this at all.
However, I'm still experiencing crashes in 3d games.
MechCommander 2 reboots when I start it - and sometimes, when I actually get it to run, it has random lockups.
Half-Life and it's mods has random crashes - usually within 2 hours.
Operation Flashpoint seem to be running pretty good..
In addition to this I experience some weird graphical bugs - like a block around the mouse pointer, or coloured lines on the desktop at startup, which goes away after a while.
I'm using AGP 4x, with FastWrites and SBA OFF. AGP 4x usually worked fine in WinME, even with FW.
I have tried reducing the hardware acceleration levels of the Geforce, and the sound card to no succes.
I have tried most the settings I could think of in the bios, and I have verified a lot of settings with WPCREDIT.
My system looks like it's in tip top shape - until I play a game.
I only have a 200watt PSU - but I never had those problems in WinME or 98, so that should not be the problem either.
I'm thinking I might have damaged the 3d prophet RAM chips - but then again, would it even run.. ?
I hope some of you might have some tips - as I have tried everything I could think of. I've also tried most the suggestions in the geforce faq (www.geforcefaq.com).
Thanks.. :\
Detonator 12.90.
VIA 4in1 4.32
Thanks.. :\
