- Jan 15, 2018
Hi everyone!
I'm planning an upgrade. The case I chose is the nzxt H510. But I'm not sure whether it's ok for my build or not.
specs:
ASUS ROG Strix X570-E
ryzen 5900x
noctua nh-d15
palit 3090 GamingPro OC
2 ssd evo 970 1tb + evo 970 plus 2tb
G.Skill Trident Z RGB
As you can see there's a hot cpu + air cooling (but I'm thinking of using custom water cooling later. not sure tho) + not the best airflow (as I've heard). I've seen some tests where they tested airflow and apparently the front fans do nothing. Still lots of people say that the temps aren't that high. I'm a bit confused here. What do you think, will 510 be ok or I have to look for something like meshify c?
specs:
ryzen 5900x
noctua nh-d15
