- Jun 17, 2003
- Maryland, USA
My 2600K is running 4.5 with auto vcore with an arctic freezer pro 7 rev2. Load temps are low mid 70s running SETI. 4.6 on auto bluescreens. Will play with manual adjustments to vcore later.
CPUz shows 1.08 and doesn't change. In the bios I saw 1.32.
One thing intel could do now that you have to buy k unlocked cpu's is have no warranty, that would suck, like they do with my motocross bike it has no warranty and cost $8199+
http://www.anandtech.com/show/4083/...-core-i7-2600k-i5-2500k-core-i3-2100-tested/2
All OCing in sandybridge is done via turbo rather than the base clocks.
Intel have a short supply of CPU's? That would be a first.
so pretty much non-K chips are maxed out at a 400mhz overclock?
Do you have a Gigabyte board? I think CPUZ has a problem reporting correct vcore with their P67 boards.
Yes, it's the p67a ud3. I did not know that about that board. Microcenter had an MSI, but considering my MSI x58 Platinum sli just died on me, I passed it over.
Mine too! I have one from a dinky little E4400 with a giant copper slug in the middle and it's about three times as high as that one. As TDP goes down in a linear fashion, the included cooling ability appears to reduce exponentially.i know it was upgraded (i read the post)
But that notua is epic. Whats up with the low profile crap???? Man my cooler that i got from a conroe looks better then that stock cooler..
