[O/C]Lamptron Touch Fan Controller Review
mdcomp
Classic Administrator
by Jeremy Vaughan (hokiealumnus)
It has been a little while since Lamptron released their flagship, FC-5 fan controller (now known as the FC5V2, which fixes screen contrast issues). In the interim they did release the FC-6, which is just a lower wattage FC5V2. Now they have leaped forward a bit and are releasing the Touch, Lamptron’s first touch-screen controller.
... Return to the article to continue reading.
Discuss this article below. If you are interested in contributing to the front page (www.overclockers.com), please feel free to contact splat, mdcomp, or hokiealumnus. For the latest updates, follow Overclockers.com on Twitter (@Overclockerscom).
Khan
well, I was going to mod my sunbeam so the led's aren't so bright when I get my 800D, but man, this just solved all my problems about touch screens and them not having enough power for my deltas.
great review, nice to see a company working close with the enthusiast community to put out a good product.
MattNo5ss
5up3r m0d3r4t0r
Good job as always hokie :thup:
I thought I'd mention that I get the same random RPM readings on my FC5V2.
hokiealumnus
Water Cooled Moderator
Thanks for the kind words!
MattNo5ss - Really? Huh...must be something they changed between the FC5 & FC5V2 b/c my FC5's readings are dead on with the same setup as before.
Does yours happen like this one? One strong fan is good but two throws it out of whack?
Mpegger
One very important question that wasn't talked about in the article: noise.
I have a different model fan controller that, from the looks of it, appears to use the same method of controlling the voltage to the fans. It tends to make a very noticeable clicking noise from each circuit when it approaches the 60% and lower setting (I'm guessing its the transistor making the clicking sound). How does this controller fair with noise in that respect?
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
My FC5(v1) was solid after I only used 1 RPM lead (not what this issue is, but figured Id mention it).
m0r7if3r
Member, Water Cooling Sticky Reading Enforcement O
Marietta, GA
I'm highly doubtful the clicking is the transistor (as in, unless it's arcing it's not), typically that is the motor in the fan that will make the clicking. It's discussed a little here http://www.xtremesystems.org/forums/showthread.php?t=223391
Mpegger
No, trust me, its the controller itself, though I too am not sure if its the transistor. Each individual circuit will make the clicking sound when the voltage is lowered beyond a certain point, though one could also call it a buzzing, just like the recent Gigabyte X58 mobos and the inductors. It's definitely not the fans clicking. These Gentle Typhoons don't click like the Mechatronics when undervolted.
hokiealumnus
No noise out of this unit in the slightest. I've got 2x .65 A Panaflos on one channel and 3x .80 A Deltas on another in my case right now. Both are running as quiet as fans of their stature can at 42% (between five and six volts).
Likewise, when testing voltage regulation at 50% with the 4x .65 A Panaflos, all was well with no noise at all. That was outside a case too, so there's nothing that could have masked any sound if it were emanating from the controller.
m0r7if3r
Marietta, GA
heh :shrug: guess you gotta buy one of these doncha!
Mpegger
What about memory? Does it retain settings between normal shut downs and/or power outage, as in a complete power loss?
Spawne32
NJ
It will retain all settings, the unit uses an ARM processor and does have memory.
