O/C Tips/Techs: ASUS KN97-X i440FX (NAT) w/P2-233
Runtime_Error
Before I get to my questions, here are the info regarding my system:
( Ive attached a System Info txt file of my system using SiSoft Sandra Pro 2001 comp analyser)
but just to get you thinking...
Program: Unicore Chip Detect v0.72 2000.03.10
BIOS Date: 08/12/98
BIOS Type: Award Modular BIOS v4.51PG
BIOS ID: 08/12/98-i440FX-<KN97-X>C-00
BIOS Eval: #401A0-0116k <-- up-to-date
Chipset: Intel Natoma 440FX rev 2
PCIset: Intel PIIx3
Superio: Winbond 877F (use 87h) rev 0 found at port 3F0h
http://www.asus.com.tw/products/Motherboard/Pentiumpro/Kn97-x/index.html
All informed?!
Good..
now here where I stand...
the orginal setting to my comp was at 233Mhz @ 66MhzFSB, then I oc'd at 300Mhz (rated, avg at 340Mhz) stiill @ 66Mhz...
Q1: there has been talk bout ppl reaching FSB of 75Mhz on these boards, and even 83Mhz(but thats just nuts!!) now, is there anyway to configure the pins on the board to have it rated at 73Mhz or anything wiriing, soldering or from what ppl also said using a P3 chip instead of the p2 ( I could do some experiementing, but I don't have the time or Money if I blow it up)
Q2: Is my MB or Chipset "clocked-locked", ppl were saying if the board was made before this date..... its not.. and after this date, it is?
Q3: by getting/buying the lastest AwardBIOS version (FLASH upgrade or socket replacement), can have a better tally on overclocking?
Finally, please don't tell me Im wasting my time.. because I just spent an entire day trying to sqeeze something out.. but no luck-so far. If I had the money I would invest in a 133FSB MB.. but I don't :)
