- Nov 1, 1998
Today in Hardware
by Dolk
Click here to continue reading.
Discuss this article below. If you are interested in contributing to the front page (www.overclockers.com), please feel free to contact splat, mdcomp, or hokiealumnus. For the latest updates, follow Overclockers.com on Twitter (@Overclockerscom).
by Dolk
Featured News:
CPU Scaling with 5970 @legionhardware.com
This is a very different type of review than what you normally read. The main purpose of this review is to show that you don't need the best CPU in order to have the highest FPS in games. This is a very true test for showing AMD vs. Intel in the gaming benchmarks. Now will this be true with all platforms? Probably not. Although, this does show show a baseline of what you could presume with other GPUs.
Consistently the i7 shows less than a 1% increase from 2.0ghz to 4.0ghz, except for CoH and CoD. With the Phenom II X4, it showed little gain to a large gain in performance when coming up from 2.0ghz to 4.0ghz. In five out of the nine games tested, the Phenom II beat the i7. This further proves the point that even the $1000 CPU can be out classed by a $300 CPU. Albeit this same test will probably show different results for different CPUs. The Core2 Duos would probably show 1% increase on each step for overclocking. The Athlon II may show a 3% change.
So what is it that creates the highest FPS in games? Is it the technology in the CPU itself? Does it really show that the i7 is not as good with games as a Phenom II? This question is left with you, the readers.
News That is A Big Deal:
News On The Side:
- Twelve C3 Revision Athlon IIs @behardware.com
- Clarkdale Efficiency: The Perfect Clock Rate For Intel's COre i5-661 @tomshardware.com
- Cooler Master Silent Pro M 600 W Power Supply Review @hardwaresecrets.com
- AMD Llano - The First Accelerated Processing Unit @insidehw.com
- How CPU Features Affect CPU Performance, Part 7 @ixbtlabs.com
- Core i3 on Athlon II @techreport.com
- LMX Superleggera Cooler Review – New Cooling King? @OverclockersTech.com
Around the Forum:
- Fermi Architecture GPUs Will Only “Hit the Full Stride” in Q2 – CEO of Nvidia @xbitlabs.com
- ATI Catalyst 10.2 Windows 7 Driver Analysis @tweaktown.com
- Gelid Tranquillo CPU Cooler Review @tweaknews.com
- G.Skill PI DDR3-2000 C7 @pureoverclock.com
- Coolink Corator DS CPU Cooler Review @vortez.co.uk
- Zalman CNPS9900 NT @tecPowerUp.com
- Intel to Dramatically Boost Capacities of Solid-State Drives by Year End @xbitlabs.com
- Most Windows 7 PCs max out memory @computerworld.com
- Intel Atom Oak Trail rumoured @Fudzilla.com
- AsRock A33ION Mini-ITX Motherboard Review @legitreviews.com
- Corsair shows its Obsidian 700D case @Fudzilla.com
- AMD Begins Revenue Shipments of Twelve-Core Opteron Microprocessors @xbitlabs.com
-Dolk
- Kingpin puts LN2 pot on RAM, Money is drained from accounts faster
- 1st Anniversary NMC Themed-Mod Contest
- Foil used as Thermal...The Tin hats of Top Hats
- Detale shows off WC system, white is the new steel
- Cadman performing mad science on Pentium D with WC cooling
- Brown399: How does Data transfer really Work? Dolk: Highways with stop lights
- i3 'Cheap Ride' showed off by SamSaveMax
- Pin Modding E5200: Arm the caps button
- Jigpu: 1 pass is friendly, 2 pass is stalking, 3 pass is law suit. (Data Wiping on HDDs)
- GT480 and GT470 Clocks? Nvidia members cry
