- Dec 24, 2000
- Milwaukee, WI
Alot of people have been posing the question as of late as to what os should they choose what follows is a quick rundown or at least the best I can of the major differences between some of them and hopefully will help someone wondering which to go with a better view of which would suit their needs better. If you are looking to stay with MS products I would recommend the following;
WindowsXP: If you are planning on running games and multimedia to the max *It is basically win9x/2k merged into one o/s combining the best of both. It has some advantages and disadvantages, the main advantage being the DirectX and game support that now abounds with XP, typically the older the game the better the chance it will run under XP. Unlike 9x based Windows os's you are not limited to the amount of physical ram you can run it with and have recognized. Recommended ram would be 512MB's. Being the latest Windows Version it is not without problems, bear that in mind. As shadow has pointed out it can be formatted and installed using the NTFS file system in addition to FAT32. If you need to further delve into which version; home or pro is best for you a little bit of research at Microsofts website should go a long way.
Currently available in two distributions;
- Home : Based solely for single processor machines
- Pro : Intended for multiple processor machines, Adds the following functions;
- : Remote Desktop - Basically a VNC (Virtual Networked Computer) Prog
- : Domain managed networks
- : EFT (Encrypting File System) Allows you to encrypt file and folders
- : More robust system restore options than home edition
- : For the power user
Windows2k: If you are planning on doing things that require alot of stability such as running servers, game support is and can be sketchy at best. Windows2k is based upon the NT Kernel, which has some very strong suits such as NTFS which is a very durable file system. Windows2k excels in many areas relating to stability as well provides some of the best Server options around aside from a Linux based solution. It also does not suffer from a physical ram limit as well. Recommended would be a minimum of 256MB's of ram.
Currently available in three distributions;
- Pro : Standard win2k os with none of the server bells and whistles *Supports dual CPUs
- Server : Same as Pro but adds all server functions such as the following;
- : E-Mail server
- : Webserver
- : File server *FTP
- Advanced Server : Same as Server but with support for up to 8 CPU's
WindowsME: ME is basically just 98SE with all the patches pre-installed. It is based upon the 9x Series of kernel, 95/98/98SE It cannot physically address more than 256MB of ram so anything more will be overkill for ME. It handles gaming quite well as well as other tasks, which makes it a good all around os if you do not want to run anymore than 256MB of ram. If you do not want to run ME I recommend you go no further back than 98SE.
Currently only one version;
- WindowsME
Non MS Products;
Mandrake 8.1: Good starter os lots of hardware support and user friendly to install
Redhat 7.2: Another popular Linux distro also user friendly
SuSE 7.3: Have yet to use but have heard great things about it
For more information regarding non-MS os's feel free to check out the Alternative Operating Systems section of the forums. If you have anymore questions please feel free to ask.
J - I hope this clarifies some of the questions commonly asked if you have anything to add please feel free, or pm me with Suggestions.
- : E-Mail server
- : Webserver
- WindowsME
Non MS Products;
