There's no way around reading your motherboard manual at least simply because the alternative is the "trial & error" approach to overclocking.
Your motherboard link is dead, is that a Shuttle nForce2 chipset motherboard?
See here
http://www.c627627.com/AMD/AthlonXP/
you have a Socket A 2200+ Sempron. It has a locked 9x multiplier.
MHz frequency = multiplier x FSB.
1500 MHz = 9 x 166.66 FSB
So you're locked at 9 multiplier and your chip may do, I don't know, 2200-2300 MHz maybe more maybe less.
So what does that mean?
2300 = 9 x 255 FSB
Some Socket A motherboards can't even handle 200 FSB, some go into low 200s, very few can go to mid 200s.
You have PC3200 RAM which can do 200 FSB for sure but if your motherboard can take it, that means
9 x 200 = 1800 MHz, so that's a 300 MHz overclock right there.
But you need a good power supply brand for overclocking and you need good cooling to take care of increased heat that comes with increasing voltage which you need to do to increase the overclock.
_____________________
AMD Athlon XP 2500+ AXMH 2500 FQQ4C
IQYHA 0348 SPMW
2 x 512MB Centon PC3200 (Samsung chips) @ 9 4 4 3
[200] FSB x 12 = 2400 MHz @ 1.85 Vcore with memory frequency at 100% [200 FSB] @ 2.90 Vdimm and 1.8 Vdd
Epox 8RDA3+ v2.1, BIOS 07/29/2004
Thermalright SLK-900A with variable speed 80x25mm Thermaltake Smart Fan 2
AIW 9600XT 128MB; Antec SX-835II case ; 380W Antec TruePower TP380
Four 80x25mm Case Fans + 1 Variable speed 80x25mm Fan YS-Tech FD1281259B-2F
