- Feb 21, 2008
- Baltimore, MD
Check my sig for full system specs. CPU was delidded with TG conductonaut between the die and IHS. MX4 between IHS and water block
I'll say that I haven't messed with overclocking since my old q6600/q9650/i7-920. So I've been out of the loop. but I started in with this chip, following this guide: http://edgeup.asus.com/2017/kaby-lake-overclocking-guide/
it was a great starting point, being that it focused on my same CPU, and most of the same BIOS options. My BIOS has an overwhelming amount of settings to tweak, making it hard to know what does what, and how useful it is for my purposes.
I want this thing to be 5GHz stable, I want it to run as cool as possible. I don't want to just hammer it with voltage.
So for now, I have a "mostly" stable setup it seems. I can run all my games and applications, and I don't see any problems with nearly all benchmarks or stress tests... EXCEPT Prime95. I dont know if its a version problem, or if prime95 isnt suited to my CPU architecture or something, but it just doesn't like my setup.
stress tests i've successfully run:
AIDA64 (CPU/cache) - 5+ hrs (max core temp, 69C)
LinX - 50runs, 5+hrs (max core temp, 86C)
Intel XTU - 5+hrs (max core temp, 70C)
Prime (small FFT) - usually fails after about 30mins. when it fails, it does not BSOD. It does not lock up. Prime95 simply reports that it got a calculation error, deems it a hardware failure, and drops a thread (50% core usage), usually after it drops one, it will drop more with more time. I'm not sure it's solely an AVX issue, as LinX uses AVX loads as well, uses a lot more RAM (like all of it), and even gets the cores slightly hotter than Prime, so what gives? I used to consider Prime the tell-all for stability, but now I'm questioning it since it's the ONLY thing that doesnt play nice.
Current BIOS settings: (if it's not listed, I left it on Auto, but there are A LOT of settings available)
Ai Tuner - XMP
XMP - DDR4 3200
BCLK - 100.00
AVX neg offset - 0
CPU ratio limit - 50
CPU cache ratio min - Auto
CPU cache ratio max - 45
CPU Load Line Cal - Level 6
VRM Spread Spectrum - Disabled
IA AC load line - 0.01
IA DC load line - 0.01
BCLK Adaptive Voltage - Enabled
CPU Core/Cache Voltage - Manual
Core Voltage Override - 1.320
DRAM Voltage - 1.353
CPU VCCIO Voltage - 1.100
CPU System Agent Voltage - 1.150
Ai Tuner - XMP
XMP - DDR4 3200
BCLK - 100.00
AVX neg offset - 0
