OC Intel Xeon W3690/R3E Need experts opinion
raziel86
Hello.
I'm trying to squeeze the last bit of performance from my old rig till I have enough money to upgrade. I managed to OC it up to 4.32Ghz but I want an experts opinion on voltages and other changes I made, if this is safe OC for 24/7 operation.
I didn't have much time to test stability I will list all the tests I made below:
30min OCCT Larg data set CORE TEMPS Low 60s (no error)
12 run Intel Burn Test (Stress level standard) CORE TEMPS High 60s (no error)
Unigine Heaven Benchmark
Unigine Valley Benchmark
3Dmark Fire strike ULTRA
NO BSOD on all benchmarks
I'm planning to run prime95 for 12 hours now to make sure that OC is stable but before that can you guys give your expert opinion on my settings so that I can run this for 12 hours with ease of mind. Thank you in advance.
My Rig specs:
CPU: Intel Xeon E3690
MOBO: Rampage 3 extreme
RAM: 12GB 2x6 Corsair Dominator GT rated 2000mhz original timing 8-9-8-24, 1.65V
GPU: Asus Strix GTX1080
PSU: Corsair AX1200W
Cooler: Corsair H100i v2 EP
My Bios settings:
Code:
Target CPU Frequency                  4320MHz
Target DRAM Frequency                  1804MHz
LN2 Mode                              [DISABLED]***
QPI Loadline Calibration              [DISABLED]***
Sync Mode                             []
AI Overclock Tuner                    [MANUAL]
OC From CPU level Up                  [AUTO]
CPU Ratio Setting                     [Min: 12, Max 63]
CPU Turbo Power Limit                 [DISABLED]
>CPU Configuration----------------------------
CPU Ratio Setting                     [24.0]
C1E Support                           [DISABLED]
Hardware Prefetcher                   [ENABLED]
Adjacent Cache Line Prefetcher        [ENABLED]
Intel(R) Virtualiyation Tech          [ENABLED]
CPU TM Function                       [ENABLED]
Execute Disable Bit                   [ENABLED]
Intel(R) HT Technology                [ENABLED]
Active Processor Cores                [all]
A20M                                  [DISABLED]
Intel(R) SpeedStep(TM) Tech           [DISABLED]
Intel(R) C-STATE Tech                 [DISABLED]
C State package limit setting         [DISABLED]
BCLK Frequency                        [180]
PCIE Frequency                        [100]
DRAM Frequency                        [DDR3-1804mhz]
UCLK Frequency                        [3608mhz]
QPI Link Data Rate                    [auto]
Memory Configuration Protect          [DISABLED]
>DRAM Timing Control--------------------------
CAS# Latency                          [7]
RAS# to CAS# Delay                    [8]
RAS# PRE Time                         [7]
RAS# ACT Time                         [20]
RAS# to RAS# Delay                    [6]
REF Cycle Time                        [88]
WRITE Recovery Time                   [12]
READ to PRE Time                      [8]
FOUR ACT WIN Time                     [24]
Back-To-BackCAS# Delay                [0]
Timing Mode                           [2N AUTO]
Round Trip Latency on CHA             [47 AUTO]
Round Trip Latency on CHB             [48 AUTO]
Round Trip Latency on CHC             [48 AUTO]
WRITE To READ Delay(DD)               [8 AUTO]
WRITE To READ Delay(DR)               [8 AUTO]
WRITE To READ Delay(SR)               [18 AUTO]
READ To WRITE Delay(DD)               [8 AUTO]
READ To WRITE Delay(DR)               [8 AUTO]
READ To WRITE Delay(SR)               [8 AUTO]
READ To READ Delay(DD)                [7 AUTO]
READ To READ Delay(DR)                [6 AUTO]
READ To READ Delay(SR)                [4 AUTO]
WRITE To WRITE Delay(DD)              [7 AUTO]
WRITE To WRITE Delay(DR)              [7 AUTO]
WRITE To WRITE Delay(SR)              [4 AUTO]
CPU Differential Amplitude            [AUTO]
CPU Clock Skew                        [AUTO]
IOH Clock Skew                        [AUTO]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode                        [T-BALANCE]
PWR Volt. Control                     [AUTO]
Load-Line Calibration                 [AUTO]
CPU Voltege OCP                       [ENABLED]
CPU PWM Frequency                     [AUTO]
Extreme OV                            [DISABLED]
Extreme OC                            [AUTO]
CPU Voltage                           [1.37500]
CPU PLL Voltage                       [1.81525]
QPI/DRAM Core Voltage                 [1.32500]
DRAM Bus Voltage                      [1.65625]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA          [AUTO]
DRAM CTRL REF Voltage on CHA          [AUTO]
DRAM DATA REF Voltage on CHB          [AUTO]
DRAM CTRL REF Voltage on CHB          [AUTO]
DRAM DATA REF Voltage on CHC          [AUTO]
DRAM CTRL REF Voltage on CHC          [AUTO]
IOH Voltage                           [1.11300]
IOH PCIE Voltage                      [1.51050]
ICH Voltage                           [1.11300]
ICH PCIE Voltage                      [1.51050]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum                   [AUTO]
DRAM Spread Spectrum                  [AUTO]
R
raziel86
Go for it! Looks good. Read the guide for c2d/c2q overclocking in the Intel ultimate sticky thread. ;)
http://www.overclockers.com/forums/showthread.php?t=515316
One thing though, that 1080 is being held back by that processor...even overclocked. You also have 1.2KW of power for a system that won't break 325W...
thanks for reply. I'm planning to get new rig somewhere this year will take my 1080 get one more to SLI with it. good to hear that I didn't mess up voltages.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
1080 sli... cool! You playing at 4k res or something? Why so much horsepower? Sorry for the questions, just making sure perception and expectations are lined up..perhaps saving you $650. ;)
That second 1080 will put you around 550W, note. ;)
R
raziel86
not right now but planning for ROG swift 4k monitor with new rig so yeah my target is 4k gaming with as much fps as I can get. :) I will take my PSU and 1080 to new build.
R
raziel86
one more thing my nvidia driver crashes and automatically recovers if I stress test intel burning test on maximum settings. Pc is running and benchmark is working no errors but driver keeps crushing every now and then anyone has any ideas on this? this doesn't happen on prime 95, OCCT and aida64 stress test. happens only on IBT. this is info from even viewer (Display driver nvlddmkm stopped responding and has successfully recovered. EVENT ID: 4101) I doubt it wll happen in any real everyday situations but still it kainda bugs me.
EarthDog
Buckeyes!
No clue. Makes no sense your gpu is crashing during an all cpu stress test...
Have your tried different drivers or reinstalling what you have?
R
raziel86
I will try to reinstall GPU drivers maybe it will help. I have latest Nvidia driver right now.
