Patikekfad
- Mar 3, 2025
Hey everyone, need help understanding some weird overclocking behavior!
I'm trying to overclock the legendary i7-4790K on an MSI Z97 PC Mate motherboard, and while I’ve had some success, I keep running into weird issues that I can’t fully explain. I am not an expert, so I’ll go step by step so you can see where things get strange and hopefully help me out. I've been able to overclock this motherboard with a G3258 Pentium in the past quite well, from 3.2Ghz to 4.0Ghz, if I remember correctly.
1. The CPU VCore and VID (Max) voltage values don't seem to match. My VCore value is seemingly stuck around 0.9v's (idle or load), even though I set it to 1.25v for example (VCore sensor from the motherboard doesn't seem to change at all, even when I do change the CPU Core voltage in the BIOS). Pre-OC my Cinebench R23 score was 4865, at 4.0Ghz. I managed to OC it (somehow, we'll get to that later), to 4.5Ghz, giving me a score of 5250 in R23. Even in this scenario, the VCore value in HWMonitor, given by the motherboard, remains around ~0.9v. The VID value the CPU reports is (in this 4.5Ghz OC-scenario) 1.20V, which is what I set it to in the BIOS. So here's the question: I know VID is what the CPU requests, but why isn’t the motherboard actually delivering it?
Now there is an built-in OC feature called OC Genie (OG), that overclocked the CPU to 4.4Ghz and disabled the Intel C-states, whilst running the VCore at 1.20v, and actually, it seems pretty damn stable! So what is going on here?
To summarize:
System Specs for Context:
CPU: Intel i7-4790K
MOBO: MSI Z97 PC Mate (No LLC option, 10 years old)
RAM: 16GB (2x8GB Kingston KHX1866C10D3/8G @ 1.5V)
GPU: MSI GTX 1650 Super
PSU: 650W (10+ years old, might be weak?)
Cooling: Cryorig H7
Monitor: 1080p 60Hz
I also increased the Long and Short Duration Power Limit's to 255 (just as the OG) and the CPU Current limit (in Amperes) at 256A.
I added 2 screenshot of my HWMonitor under load in AIDA64 in the stable 4.5Ghz OC setup, which actually managed to run for 8 hours now!
Thanks a lot, and please let me know if you'd like to know some extra information!
- This motherboard does not have LLC, so I can't really fix potential VDroop that way. I could try my luck with adaptive+offset mode instead of override, on the CPU Core Voltage setting in the BIOS maybe?
- I've tried to increase the VCCIN voltage from 1.80v to 1.90v, but also that didn't seem to help.
- Disabling Intel C-states (Package C State Limit) actually made my computer crash within 5 seconds of the R23 benchmark test.
- I do have the latest drivers installed, V4.11
To summarize:
- Why is my CPU VCore still so much lower than what I set in BIOS?
- Why does disabling C-States break my overclock, even though Overclock Genie does it just fine?
CPU: Intel i7-4790K
Cooling: Cryorig H7
Monitor: 1080p 60Hz
