I think you're temps are ok... increasing the vcore to 1.7v should get you stable at where you're at now. To go higher I see two possible problems: RAM and/or PCI bus speed too high. To see if it's the RAM holding you back, try using the 1:1 ratio and see if you can overclock higher and stay stable. You can always buy better RAM if needed. What motherboard do you have? Can you "fix" the PCI bus. At 115 FSB, the PCI bus is at 38 MHz. I've never gotten much higher than that and stayed stable. If you can fix the PCI bus, then that solves that problem.
