- May 29, 2003
- Montreal, Canada
I recently bought a new CPU, the XP1800+ with 1.5v core. It overclocks quite well. I'm getting 2080mhz pretty easily. If I had a 6/1 divider, I'm sure it go quite a bit higher. However, my computer seems to be rebooting about once every few days. Can this be due to the PS? Or should I bumb up the core voltage a bit? The PS is currently the one that comes with the Antec Lanboy. 350 claimed watts I believe. How much does the PS influence the overclocking ability? I'm a little new at this and wanted to know if any of you have any ideas. Here are my voltages...
3.3V reading 3.5V
5V reading 4.84V
12V reading 11.86V
I have no idea what the negative values mean or even if they're connected to the right sensor, but here are the values anyways. I think they may be attached to the wrong sensor or maybe the mobo doesn't support these readings through MBM.
-12V reading -7.17V
-5V reading 0.89V
These are the specs to the system.
1800+ JUIHB-DLT3C running at [email protected] FSB 180.4Mhz
Memory: Kingston Hyper-X PC3000
PowerSupply: Antec 350W SmartBlue
Mobo: KX7-333
CPU cooler: AX-7 w/Panaflow H1A
Idle temp: 45
Load temp: 52
If someone here knows why it may be rebooting, I'd appreciate any ideas.
Thank you
3.3V reading 3.5V
5V reading 4.84V
12V reading 11.86V
-12V reading -7.17V
-5V reading 0.89V
Mobo: KX7-333
Idle temp: 45
Load temp: 52
Thank you
