- Jul 10, 2005
- Ellicott City, MD
Is there any calculators out that will calculate overclocked wattage? Thinking about a pelt.....
elaborate plzOC Detective said:Thing is the base TDP is dependant on the thermal profile and Tcase max for the individual opteron cpu.
ok, so it's 85.3W (from AMD processor spec finder)OC Detective said:I should also point out that none of the rev E Opterons are 89W - the older socket (rev CG) 940 ones were though.
You appear to be missing the point and I suggest you read The Coolest's thread about this. The 110W you are referring to (presumably from amdcompare.com) is as I have said the absolute worst case scenario for the highest applicable Tcase max for the given thermal profile.Aphex_Tom_9 said:35W DC? AMD's processor spec thing says it's 110W for all DC opterons...
