- Oct 20, 2003
I'm trying to oc my 2.8c on an intel d865perl motherboard, as it stands this is the STOCK info
2.8C P4, family F, Model 2, Stepping 9, Revision D1
0.13nm fab
512mb Kingmax PC3200 DDR (2X 256mb)
Detailed info on memory
CPU-Z version 1.20a
Memory Modules Serial Presence Detect (SPD)
Module #1
General
Memory type DDR-SDRAM
Manufacturer (ID) Kingmax Semiconductor (7F7F7F2500000000)
Size 256 MBytes
Max bandwidth PC3200 (200 MHz)
Part number MPWB66D-38KT3R-PBA
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 133 200
CAS# 2.0 2.5
RAS# to CAS# delay 3 3
RAS# Precharge 3 3
TRAS# 6 7
Module #2
General
Size 256 MBytes
Part number MPWB62D-38KT3R-PBA
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5
RAS# Precharge 3 3
TRAS# 6 7
I have a few questions about this setup
1. What program can i use to overclock the cpu/motherboard, this board is not at all oc friendly and i will have to use a secondary prog to oc. I've tried SoftFSB and CPUFSB but neither have support for my motherboard and PLL chip.
2. CPU-Z reports my memory running in single channel mode, but i know the memory is dual channel. And CPU-Z also reports the memory as not having performance mode enabled, is this available with these memory sticks?
3. Every time I boot, the system reports the memory as being unmatched, but as shown by the CPU-Z info above, they are matched in every respect.
Any info would be GREATLY appreciated
0.13nm fab
CPU-Z version 1.20a
Module #1
General
Size 256 MBytes
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5
RAS# Precharge 3 3
TRAS# 6 7
Module #2
General
Size 256 MBytes
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5
RAS# Precharge 3 3
TRAS# 6 7
