OC'ing my AMD XP 1700+
Stalka
Phx, AZ
Sup Homies...
Just a quick qeustion... do u think that if i OC my amd xp 1700+ pross (my multi is 11 and my fsb is 133) like 6mhz more fsb that my system would run stable? i run at 1467mhz now if i cange my fsb to 138mhz (6mhz more than b4) i will run at 1.518mhz
so do u think that my system will run stable? (i have a volcano 6+ and a 120mm fan in the front bottom of my case(fyi))
FIRESTARR357
That depends on temps and what you have in your PC.I would say yes first what ya do is download prime95 then go up slowly till your PC starts to mess up erros bluescreens and lockups ect.Then back off slightly and run prime95 overnight if it don't crash it's stable.
S
Stalka
Phx, AZ
Thanx for the posts guys you both helped me out alot!!! im gunna try if not ill come back at let everyone know heh
KingB
Calgary, Alberta
What Mobo do you have?
I have the same CPU. I can get up to an FSB of 145 on my system. I have a pretty averge hsf but I live in Canada with a room temperature of about 15c (60f). Yeah its cold but It keeps my comp stable. Still need to work on case ventilation though.
Moving to watercooling soon so hopefully I can turn up the thermostat soon and keep going OCing higher thru the summer months as well.
You should get 138 no problem.
Welcome to the forums.
S
Stalka
Phx, AZ
im running a ECS - K7S5A motherboard with 768 sdram and my pross fan is a volcano 6+
S
Stalka
Phx, AZ
im having some trouble OC'ing on my mobo... my fsb, voltage and ratio setting are lokced in my bios... and my mobo isnt supported in SoftFSB so an have an idea or solution to how i can up my fsb to like 138 (from 132.77)? my multi (cpu ratio) is at 11. any help would be great thanx
maxima88
Flounder 43 did include a link (i think) for the overclocking bios.
I upped my fsb from 133 to 138 thru bios.
I then d/l CPUFSB and upped my fsb to 147 there. I can sometimes up my fsb to 150 but it runs somewhat unstable so I keep it at 147.
S
Stalka
Phx, AZ
how do i use Prime95 and/or CPUfsb ? im a little confused with em both someone wanna point m in the right direction... plz
Thanx
BSims66173
OC 1700XP
I have my fsb at 150 and my multiple is 11. Mine is running fine at 1650mhz. My cpu temp runs 43c and case is 36c. I have the dragon+ mb and the 1700xp cpu.
Silver
Senior Citizen (aka old fart)
Dallas, Georgia
Re: OC 1700XP
Welcome to the forums...you in the right area?
SpoonMaN
Olympia Washington
yeah i have the same CPU also...and the same heatsink in fact and i run just fine at 1650Mhz
however i do run at 1.89volts on a EPoX 8KHAL and i have a swiftec MCX462-b in the mail right now
i plan on getting at least another 100Mhz out of this
i also have 256mhz of OCZ PC3000u DDR ram and maybe gonna unlock it too
im just hoping mt gf2 GTS card (best $50 3d card ever) dont mind the 80mhz AGP bus ?
S
Stalka
Phx, AZ
Re: OC 1700XP
sims, what hsf are u sporting? and what kind of cooling u gots going in there?
