- Jul 12, 2002
Just got a Asus Strix 1080ti (non OC version).
I've followed the Asus ROG guide, where the OP starts with +70 on the core and +200 on the mem. I did initially use Asus GPU tweak but I just prefer MSI afterburner. Anyone else feel this way?
I'm also trying to figure out how to have my core clock value display below my GPU temp in terms of OSD Monitoring if using MSI. I believe that in order to have OSD with Asus Tweak one must install XSplit Gamecaster? I haven't tried this yet.
So in terms of my OC, I'd love to achieve a 2000mhz OC on this card and from my understanding increments of +10 is the way to go? I'm using Valley and Heaven for testing stability after which I go into a game (Kingdom Come deliverance) and mess around.
In terms of mem clock, I'm not sure what to expect? If I should be doing +10 increments on that also?
I slapped the power limit to 120% and voltage to 100% also, which gives a 0.02v increase.
The card does 1860/5508 out of the box with nothing changed. (This is when I open render test with gpu-z) The boost value in gpuz shows 1607
Thanks for any useful tips as well as if there's a way to have all OSD values show one below the other with MSI monitoring (this I can't figure out)
