I have an AMD Athlon XP 1600+ running at 1.4ghz (stock) and an Asus A7N8X Deluxe Retail motherboard.
The CPU FSB is at 133 default, which is 1.4ghz. I took it up to 166 CPU FSB but it was to unstable so I took it back down to 133. The default multiplier for my chip is 10.5. I took the multiplier up to 11 though so shouldn't that take up the mhz? I haven't unlocked but, but if it was locked would I even be able to adjust the multiplier in the BIOS? Isn't increasing the multiplier just the same as increasing the CPU FSB per say, but its just doing it in tiny increments?
Also, can someone explain this to me:
"11x200 (2200mhz aka 3200+) to 11x215 (2365mhz)"
the 200 and the 215 are the CPU FSB that you took up? Or whats the name for it? The only things I can change for my CPU in BIos is the CPU FSB, which can only be taken up by like 100/133/166/200, so how did you get 215 and stuff?
Thank you for your help
