OCZ DDR Booster + BH-5 oc'ing
eva2000
Brisbane, Australia
Well first benchies with OCZ DDR Booster :)
2.8C SL6Z5
Asus P4C800-E rev2.0 1016 bios
256MB Gecube X800Pro @ stock
2x 256MB Kingston HyperX PC3200 KHX3200K2/512 BH-5
80GB WD 800JB
550W Antec TrueControl
WinXP Pro SP1
1:1 cpu/ram ratio
@ 257mhz 2-2-2-6 at 3.4v (LED)
vAGP = 1.6v
PAM = AUTO
DDR Idle Timer = Infinite
DDR Refresh Rate = 64usec
PM = Turbo
Spread spectrum = Disabled
AGP Aperture = 64MB
AGP/PCI = 66.66/33.33
CTIAW Bandwidth = 7235.2 MB/s
Sandra 2004 STD SP2
CPU = 10,739 / 4563/8001
CPU Multimedia = 27,741 / 39,502
Buffered = 6418 / 6350
Unbuffered = 3677 / 3681
Aida32 3.93
Read = 6134 MB/s
Write = 1959 MB/s
SuperPi
1M = 38s
2M = 1min 27s
8M = 6min 58s
16M = 15min 28s
32M = 33min 58s
Hexus Pifast = 54.28s
TheLab Pifast = 36.47s
Very nice just wish the LED went to 2 decimal places rather than 1 decimal place.
eva2000
eva2000
Brisbane, Australia
direct from OCZ for testing purposes :D
Without OCZ DDR Booster that same ram only did 240-245mhz 2-2-2-6 at 3.18v on Abit AI7. On Asus P4C800-E without the booster probably only be able to do 217-220mhz 2-2-2-6 at 2.85v.
tomvill
Ontario, Canada
Thats a decent improvement. I'd like to try on on my BH-5 and see what I can get out of it with 2.85 volts now I can only get 230 fsb on Mushkin Level II Pc 3500 but my Vdimm moded board is down till I can replace the Vdimm mosfet. Maybe it,s worth a try cause the Vdimm mosfet gets so bloody hot even with a heatsink on it.
eva2000
eva2000
Brisbane, Australia
with same ram above on P4C800-E I tried a lower more acceptable 3.1v vdimm (LED) and easily get 245mhz 2-2-2-6 and at 3.3v (LED) get stable 250mhz 2-2-2-6 which is spot on for what average BH-5 can do :)
FYI, trying a single 256MB KHX3200K2/512 BH-5 stick and it's doing memtest fine at
255mhz 2-2-2-6 at 3.1v
260mhz 2-2-2-6 at 3.3v
265mhz 2-2-2-6 at 3.4v
270mhz 2-2-2-6 at 3.5v
eva2000
eva2000
Brisbane, Australia
well talk about the true power of BH-5 ram
1x 256MB KHX3200K2/512 BH-5
@ 270mhz 2-2-2-6 at 3.5v (mid)
OCZ DDR Booster powered
:cool:
eva2000
eva2000
Brisbane, Australia
Now to see what 1 stick in single channel will do with OCZ DDR Booster :)
2.8C SL6Z5
1x 256MB Kingston HyperX PC3200 KHX3200K2/512 BH-5
80GB WD 800JB
WinXP Pro SP1
vAGP = 1.6v
PAM = AUTO
PM = Turbo
AGP Aperture = 64MB
1:1 cpu/ram ratio
@ 270mhz 2-2-2-6 at 3.5v (LED)
Buffered
Unbuffered
Jarlax
Asylum
Very nice results!! I can't wait till these are available. I checked out Frozencpu and they are just pre-order. Any one know when the actual release date is? I would love to see what this can do for my BH-5 Buffalo 3700 sticks!
kiyoshilionz
Wheaton, IL
I have a feeling that these are only good for people with either BH-5 or Intel systems. Intels are always RAM restricted overclocking, and BH-5 loves its high voltages. For regular AMD systems (Athlon XP as far as I know) it seems that we are motherboard/chipset restricted in our RAM/FSB overclocking.......at least I know mine is, I can only get 240 stable with DDR500 RAM........
So this isn't worth it for my system :-/ Now if only they had one of these for chipset voltages.....
Jarlax
Asylum
eva2000 said:
they're pre-order as they sold out
But did they actually sell out or have they never had any in stock? I don't think the Booster is available for retail sale yet. Which means that they are not sold out, but that they have never had any to sell yet. If the Booster is ready for retail, then why is it so hard to find???
But I could be wrong.
JTanczos
Eastern Pennsylvania
If you check the compatibility list youll see alot of AMD motherboards arnt compatible with it. At least Nforce2 boards. Also it seems alot of boards are limited to 3.4 volts anyway.
So if your board can handle it then I say go for it. Otherwise it doesnt matter anyway.
JT
JoT
You can't fire me, I have
3.4v is still a crazy voltage. Nice o/cs there, man :thup:
kiyoshilionz
Wheaton, IL
JT
I know it's compatible, but it's not what holds back mose Nforce AMD motherboards. With high-speed RAM, the restriction isn't the RAM anymore, it's the chipset and the motherboard, which can't be taken care of by a Vdimm booster. But for those without high-speed RAM, then this is probably a safer version of a voltmod.
eva2000
eva2000
Brisbane, Australia
more OCZ DDR Booster powered results with Prime95 v23.8 tests too :)
2.8C SL6Z5
Asus P4C800-E rev2.0 1014 bios
64MB Albatron MX480EL
80GB WD 800JB
WinXP Pro SP1
2x 256MB Corsair XMS3500C2v1.1 winbond BH-5
1:1 cpu/ram ratio
@ 255mhz 2-2-2-6 at 3.4v (LED)
OCZ DDR Booster Powered
vAGP = 1.8v
PAM = AUTO
DDR Idle Timer = 16T
DDR Refresh Rate = 15.8 usec
PM = Standard
AGP Aperture = 64MB
