- Nov 30, 2004
Best over clcoking mobo for Q6600 ?
OK I am looking to replace the Asus mobo I have as I have been having a terrible time with v-drop and I hate it
Any way as some have suggested I should do some research and well I have been doing just that and as I have been looking I decided to start to look for some thing that is fully compatible with the RAM I have not just Chipset and voltage and the such . I went onto the OCZ site to see just what mother boards they recommend for that very RAM I have . This is what I have found out .
http://www.ocztechnology.com/products/memory/ocz_ddr2_pc2_8500_sli_ready_edition
I went to the NVIDIA® SLI™- certified tab and clicked it this popped up this .
http://www.slizone.com/object/slizone_ecosystem.html#certified_memory
Looking through this I found these mobo's
http://usa.asus.com/products.aspx?l1=3&l2=11&l3=610&l4=0&model=1981&modelmenu=1
http://www.msicomputer.com/product/p_spec.asp?model=P7N_Diamond&class=mb
http://www.evga.com/articles/385.asp
With the XFX site not putting up the required information . After digging around I found this on the site .
http://www.xfxforce.com/en-us/products/motherboards/7series/780i.aspx#2
So my question is this I know that my mobo doesn't officially support the RAM I have and I am not going to get some new stuff as I really like this RAM .
I was looking at this mobo http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
And well now again I am confused if Intel this Chipset will even support the RAM I have as well it sure doesn't support Nvidia clearly ( If they did why did they ONLY make crossfire mobo's ? ) and if it doesn't support Nvidia is there any reason I should go with the P5Q-pro over any of the other mobo's that clearly support the Killer RAM I have ?
AS you all know any help is greatly needed .
This is a big decision and as I willy nilly jumped into a mobo the last time I want to make the right choice this time and that choice has to be taking every thing I have into consideration not just one piece of hard ware but all of them . CPU , RAM , Video card , HDD and even the PSU .
