OCZ Water Cooling kit - Discontinued..
rbdaniel@bellso
Miami
Hello Guys
FYI:
I sent an email to OCZ about there Water cooling kit and this is what I got back. It Seems they are updating the product..
Hi,
Thanks for your interests of our watercooling product! However,
we only sold limited amount of units and decided to discontinue this product for future revision. If you have not bought this product, we suggest you to wait until new revision comes out. If you have any other questions, please feel free to let us know. We would be happy to answer them for you.
Sincerely,
Technical Support
Phone: 408.733.7600
Fax: 408.733.5200
Email: [email protected]
www.ocztechnology.com
Too bad for me this was the one I had decided to buy. It had a good set up and it was very fairly priced. Have to wait or find something else..
Daniel Rodriguez
It is on the OCZ website.
HERE
I was looking at it when they released it... Pretty run-of-the-mill (a lot worse than some other kits I have seen), not looking too great I'm sad to say. Small tubing ID, a sketchy looking radfiator, and generic waterblocks made it less than superb as far as I'm concerned. OCZ makes damn good RAM, and Ramsinks, but this didn't sell well for a good reason (apparantly OCZ's thermal compound is as good as AS3 BTW).
Chek the link for yourself though. (I would rather get the Swiftech kit and be done with it! :) )
rbdaniel@bellso said:
Hello Guys
FYI:
Hi,
Sincerely,
Technical Support
Phone: 408.733.7600
Fax: 408.733.5200
Daniel Rodriguez
That kit being discontiued was probably a good thing. If your into kits check out www.dtekcustoms.com or www.dangerden.com
Hello Guys
Thanks for your replies. Yes you are right, I should keep looking around.. There are other choices..
Thanks
Daniel
