Odd voltage reading
Wonko The Sane
Port Richey, FL
I have a dual celeron system with both cores set to 2.2v. in MBM 5 one core displays as 1.5v. does anyone know what could cause this? here is a screenshot of the MBM readings. Thanks in advance.
*edit:
I'm using an abit bp6 with celeron 400's
Cluster
Canuckistan
I doubt that the reading is accurate. If the Vcore is set to 2.2 and is reading 1.5 then the processor wouldn't be running if the voltage was reading right.
Yodums
Senior Member
Ottawa, Canada
I heard a dual board have a habit of tuning only one processor, what is the default vcore of those Celeron's?
Wonko The Sane
Wonko The Sane
Port Richey, FL
default vcore is 2.0v. and both are on and recognised in windows. the chip has to be running at the correct voltage, i would say it's a problem with the sensor, but if anyone knows of a way i can double check i would appreciate it.
