- Feb 10, 2002
- Chicago burbs
Hello Overclockers,
I've been reading through the forums for a few weeks now, and I've still got some questions about DDR memory that are bothering me.
Ok, I understand how to calculate theoretical bandwidth. Please correct me if I speak incorrectly about something.
FSB * 2(double data rate) * 8(bytes per cycle) = Bandwidth(MB/s)
example: 133Hz *2*8 = 2128 =approx= 2100 MB/s
Now, I start to get confused when it comes to 2400 and 2700 bandwidths. for these to operate at advertised levels, the FSB would have to be 150 and 166 respectively. I also understand RAM is backwards compatible, so if you plugged a 2700 chip into a motherboard with a 133 FSB, it would operate at 2100 MB/s. So, to achieve 2700, you would have to raise FSB to 166. So someone would only want to buy a 2400 or 2700 stick if they were planning on overclocking or already had a higher FSB.
However, I've heard that on many motherboards you can change the memory clock speed without changing FSB by raising it manually and lowering it through dividers. Is this right?
So if I had a 133 FSB machine that I knew I wasn't going to try to go much past 150 FSB, wouldn't I be safe buying a cheaper stick of 2400 ram like this instead of the more expensive crucial ram?
I look forward to your comments
Chris-the dude
Chris-the dude
