- Nov 16, 2004
sorry no pics, but I thought I'd share my lapping results with yall..
system:
Asus P5B (basic)
E6600 (8X333 = 2.66ghz)
Zalman 7700 fan
Pre-lapping temps were roughly 27-29 idle, 46-50 load. Ambient temperature 24C (76F)
I decided to go with 600, 800, 1000, and 1500 for the lapping job (bought it at Autozone)
After removing the Zalman, I noticed the thermal paste had a HUGE gap going straight down the middle from top to bottom of the CPU. I had no idea what this meant (my first computer build). The bottom of the heatsink was very polished and reflective, but it had a very slight curve in it's shape, so I figured it wasn't making good contact with the processor.
I followed the lapping method prescribed the forums--taping the sandpaper to a flat piece of glass, and rotating the heatink 90 degrees every 10 strokes. After roughly 45 minutes, I was done...The bottom wasn't a perfect mirror, but it looked much flatter which is the whole idea behind lapping. After applying a paper-thin layer of Arctic Silver 5 with a razor blade, I remounted the heatsink and booted up.
Much to my disappointment, NO CHANGE IN TEMPS! Arrrg...$20 down the drain...What went wrong?
So I decided to try again...popped the Zalman off, and what do I see? The same HUGE chunk of empty space down the middle of the CPU...WTF?
Obviously the problem was not with the heatsink...but with the processor itself. Now I was SCARED TO DEATH to touch the CPU...I had no idea how to lap such a skinny thing (what to hold on to?), but I said fark it...NO GUTS NO GLORY! And out it came.. Being careful not to touch the gold pins on the bottom, I held all four corners of the CPU and used the same lapping method as before (one piece of advice--put band-aids on your fingertips BEFORE you lap a CPU...because you won't feel your skin rubbing away until it's too late...ouch!)
The 600 grit really made a big difference. It was obvious there was a huge camel "hump" on the processor. The copper color came through the middle almost immediately, but it took 3 full pieces of sandpaper and 20 minutes to erase the last bit of the gray metal from the 4 corners of the CPU. I probably took 1/4cm off that sucker just to get a flat surface.. After finishing up with the higher grits, I cleaned it with a lint-free cloth, reapplied AS5, and gave it another try.
BOOYAH! 3 degrees lower! Idle temps are now around 25C, and load around 45-46C.
Lesson learned: If you are going to lap something, GO ALL THE WAY! The only way to ensure proper (perfectly flat) contact is to lap the heatsink AND the CPU. A flat heatsink will do you little good if you have "humps" or "valleys" on your processor. Be careful, take your time, and enjoy the lower temps!
system:
Asus P5B (basic)
Zalman 7700 fan
