- May 10, 2009
(Please note this is a work in progress and may change somewhat, don't let this discourage you! Anything you submit will stay listed, it may just move slightly)
This thread is for all to submit their WPrime 1024m scores for a Categorized Top List. Scores for a Categorized Top List. All OCForum members have a chance to be listed here! This is not exclusive to OCF Benching team people. While this is a nice and friendly intraforum competition thread, this thread is also useful as a reference for what your score should and can achieve with this benchmark.
If you are unfamiliar with WPrime 1024m, please click here and read this page.[/B]
To download the proper version of WPrime, click here.
READ THESE INSTRUCTIONS BEFORE POSTING!
1) You must use this version of WPrime: Link
2) Be sure to click "Advanced Settings" in WPrime and set the number of threads! Generally you need the same number of threads as CPU cores (x2 for HT cpus).
3) Run the 1024M test.
4) Take a screenshot of the finished WPrime run and CPUz memory and main tabs.
Your screenshot should look like this:
5) Post the screenshot in this thread, either as an attachment or hosted elsewhere.
6) Alternatively, a link to a HWBot submission works fine too.
7) Done!
The following format is preferred, but not necessary:
[*B]USER[/b] - [*URL="http://link-to-screenshot-or-HWBot-score-goes-here"]SCORE[*/URL] - CPU @ CPU SPEED - MEMORY SPEED/TIMINGS, COOLING (AIR,H2O, DRY ICE, LN2, ETC.)
Example: [*B]Bobnova[/b] - [*URL="http://hwbot.org/community/submission/1011431_bobnova_wprime_1024m_core_i3_540_4min_29sec_225ms"]4m 29.225s[*/URL] - i3 540 @ 5633Mhz - DDR3@734mhz 7-7-7-16. (Dry Ice)
You can copy the example and paste your info in it!
(Leave asterisks in place until I have your score posted, then edit your post if you want to.)
You may also leave the link at it's default and attach your screenshot to your post.
If you would like to see the scores of the benchmarking team, you can see those HERE (Thanks Voidn!!!). A lot of these guys run extreme cooling and have a lot of tricks and tweaks up their sleeves to reach those scores. If you are interested in joining the benchmarking team and raising your scores, please CLICK ME. In here once you completed your 10 benchmarks and joined OCF at Hwbot, you will gain access to the benching lounge and get to share and learn some of the secrets of our team! You will not find a better group of guys to learn and share tricks and tweaks with!
Overall Top Guns Multiprocessor/server (best score per person):
1.Voidn - 1m 26.673s - x5660(x2)@3192mhz - 667 9-9-9. AIR
2.Woomack - 2min 32 sec 661ms - 2x Xeon 5530 @ 2x 2665MHz - DDR3 1066@ 533MHz/7-7-7-20 1T ( stock air )
3.GoD_tattoo - 2m 52.857s - 2x Xeon E5540 @ 2.5ghz - 533mhz/7-7-7-20, Air
Overall Top Guns Single Processor (regardless of CPU type, one score per person):
AMD:
One core:
1.xsuperbgx - 14m 47.750s - AMD Sempron 140 @ 5307Mhz - DDR2@734mhz 4-3-3-9. (LN2)
Two cores:
1.OptyTrooper - 11m 32.343s - Athlon 5000+ (kuma) @ 3365Mhz - DDR2@ 305.9MHz 5-3-3-12
2.CgS Drone - 12m 8.187s - Athlon 64 6000+ X2 @ 3761.2Mhz - [email protected] 5-5-5-15 1T. (Dry Ice)
3.Dr. McCoy - 13m 1.765s - A64 Opteron 175 @ 3223MHz / 1024MB DDR @ 230MHz / CL2 3-3-6 / H2O
Three cores:
1.ChanceCoats123 - 5m 46.546s - Phenom II 720 @ 4455Mhz - DDR3@720mhz 6-6-6-20-24-1T. (Dry Ice)
Four cores:
Six cores:
Intel
One core (without HT):
1.
One core (with HT):
1.
Two cores (without HT):
1.xXSebaSXx - 11m 34s 140ms - E6300 @ 3850Mhz - DDR2@550mhz 5-5-5-15-42-2T (DICE)
2.Mario1 - 11m 56.610s - Intel E5400 @ 3535 mHz - 1GB [email protected] mhz 6-6-6-18, stock cooling.
3.Noshei - 18min 29sec 624ms - Mobile Core 2 Duo T9550 @ 2.66GHz - DDR3 @531.8MHz 7-7-7-20
Two cores (with HT):
1.Bobnova - 4m 29.225s- i3 540 @ 5633Mhz - DDR3@734mhz 7-7-7-16. (Dry Ice)
2.Woomack - 5min 14 sec 903ms - Core i3 540 @ 4900MHz - DDR3 1600@ 852MHz/7-6-6-18 1T ( H2O )
3.SamSaveMax - 5m 21.422s - i5 650 @ 4750.9MHz - DDR3 @ 950MHz/9-9-9-24 1T (AIR)
5.Georanma - 15m 23.007s - i3 530 @ 4.3674 GHZ - ddr3 595MHz/6-6-6-15, Air
Four cores (core2quad):
1.Earthdog - 4m 23.253s - Q9650 @ 4635Mhz - DDR2@515mhz 5-5-5-15. (H20)
2.SamSaveMax - 2m 59.602s - i7 2500K@5504mhz DDR3@800-6-8-6-24 (AIR)
2.discman - 3m 5.984s - i5 2500k @ 5289.8Mhz - [email protected] 9,9,9,24 1T Air
3.SamSaveMax - 3m 30.140s - i5 750 @ 4607.7Mhz - DDR3@1097mhz 8-9-8-22 88-1T (AIR)
Four cores (Core i7):
Six cores (with HT):
1.spiritedandy - 1m 30.433s - 980x @ 5680Mhz - DDR3@1014mhz 7-7-7-20 1T (Rotary Cascade)
2.Bobnova - 1m 36.327s i7 980x@5185 ddr3@762-7-7-7-18 (dry ice)
3.nzaneb - 1min 49.169s - i7 980X @ 4589.6mhz - DDR3 @ 799.2mhz 7-7-7-20, (Just air for now)
Eight cores (with HT):
1.Woomack - 2min 32 sec 661ms - 2x Xeon 5530 @ 2x 2665MHz - DDR3 1066@ 533MHz/7-7-7-20 1T ( stock air )
2.GoD_tattoo - 2m 52.857s - 2x Xeon E5540 @ 2.5ghz - 533mhz/7-7-7-20, Air
Twelve cores (with HT):
1.Voidn - 86.673 - x5660(x2)@3192mhz - 1333 9-9-9. AIR
7) Done!
- spiritedandy - 1m 30.433s - 980x @ 5680Mhz - DDR3@1014mhz 7-7-7-20 1T (Rotary Cascade)
- Bobnova - 1m 36.327s i7 980x@5185 ddr3@762-7-7-7-18 (dry ice)
- spiritedandy - 1m 46.453s - 980x @ 4833Mhz - DDR3@1870mhz 7-8-7-20 1T (H70 corsair)
- nzaneb - 1min 49.169s - i7 980X @ 4589.6mhz - DDR3 @ 799.2mhz 7-7-7-20, (Just air for now)
- I.M.O.G. - 2m 14.797s - 1090T @ 5771Mhz - Gskill Tridents @ 770Mhz 7-7-7-15 (LN2)
- dejo - 2m 24.359s - I7 920 @ 5250 DDR3@2000 9-9-9-24 (Dry Ice)
- Dolk - 2min 34.453s - 1090T@5057MHz (DICE)
- xokeman - 2min 42.828s - 1090t@5106 ddr3@740mhz 7-7-7-24(Dry Ice)
- SamSaveMax - 2m 52.209s - i7 930 @ 4448.4MHz - DDR3 @ 847MHz/8-9-7-22 1T (AIR)
- Woomack - 2min 56 sec 764ms - Core i7 920 @ 4404MHz - DDR3 1600@ 838MHz/7-6-5-18 1T ( H2O )
- PolRoger - 2m 59.602s - i7 2500K@5504mhz DDR3@800-6-8-6-24 (AIR
- Troy - 3m 4.801s - Corei7 930@4312MHz - DDR3@748MHz 8-8-8-24 (water)
- discman - 3m 5.984s - i5 2500k @ 5289.8Mhz - [email protected] 9,9,9,24 1T Air
- GoD_tattoo - 3min 08 sec 619ms - Core i7 860 @ 4179mhz - 570mhz/8-7-7-19, Air
- redduc900 - 3min 10sec 420ms - i7 860 @ 4103.2MHz - [email protected] 9-11-9-28. (AIR)
- bda1967 - 3m 12.970s - i7 920 @ 4000Mhz - DDR3@800mhz 9-9-9-24. (AIR)
- xXSebaSXx - 3m 56.109s - AMD PII 555BE (x4) @ 4902Mhz - DDR3@688mhz 8-8-8-20-27-1T. (Dry Ice)
- Old H-Ware Tech - 4m 18.390s AMD 955 BE @ 4565Mhz DDR3 @ 810.1 CL9-9-9-24 1T
- Earthdog - 4m 23.253s - Q9650 @ 4635Mhz - DDR2@515mhz 5-5-5-15. (H20)
- A-Dub - 4m 23.703s - Phenom II 965 @ 4646 - DDR3 @673 7-7-7-21-26 1T, DICE
- CgS Drone - 4m 36.109s - AMD 955BE @ 4200Mhz - DDR3@667mhz 9-9-9-28. (Air)
- ChanceCoats123 - 5m 46.546s - Phenom II 720 @ 4455Mhz - DDR3@720mhz 6-6-6-20-24-1T. (Dry Ice)
- OptyTrooper - 11m 32.343s - Athlon 5000+ (kuma) @ 3365Mhz - DDR2@ 305.9MHz 5-3-3-12
- Mario1 - 11m 56.610s - Intel E5400 @ 3535 mHz - 1GB [email protected] mhz 6-6-6-18, stock cooling.
- Dr. McCoy - 13m 1.765s - A64 Opteron 175 @ 3223MHz / 1024MB DDR @ 230MHz / CL2 3-3-6 / H2O
- xsuperbgx - 14m 47.750s - AMD Sempron 140 @ 5307Mhz - DDR2@734mhz 4-3-3-9. (LN2)
- Georanma - 15m 23.007s - i3 530 @ 4.3674 GHZ - ddr3 595MHz/6-6-6-15, Air
- Noshei - 18min 29sec 624ms - Mobile Core 2 Duo T9550 @ 2.66GHz - DDR3 @531.8MHz 7-7-7-20
AMD:
One core:
Two cores:
Three cores:
Four cores:
- I.M.O.G. - 3m 3.499s - 965BE @ 6296Mhz - Gskill Tridents @ 832Mhz 7-7-7-15-20-1T (LN2)
- CgS Drone - 4m 40.484s AMD 955BE @ 4104.3Mhz - DDR3@720mhz 7-7-7-24. (Air)
- Dolk - 4min 53sec 31ms - Phenom II 940 @3900MHz (H20)
- bda1967 - 5m 33.478s - Athlon II X4 635 @ 3711.8Mhz - DDR3-1600@683mhz 7-7-7-20. (AIR)
Six cores:
- I.M.O.G. - 2m 14.797s - 1090T @ 5771 - Gskill Trident @ 769/7-7-7-15, (LN2)
Intel
1.
One core (with HT):
1.
- SamSaveMax - 2m 24.015s - i7 2600K @ 5322.6MHz - DDR3 @ 1071MHz 8-9-8 28 1T (AIR)
- SamSaveMax - 2m 48.484s - i7 930 @ 4493.8Mhz - DDR3@856mhz 6-8-6-22 60-1T (AIR)
