If TRIXX is keeping the volts to what you set them at under load and idle its probably not a bad thing, trust me.
I'm installing MSI Afterburner and installing TRIXX right now to see if it does the same for me, because i want it to
True. Some cards have a more robust power section. This helps with getting more clean and stable power to the GPU. This is nothing new.Again i don't know.... but my thinking is perhaps some cards have better voltage regulators that others. or better PCB's. on some of those the vDroop is perhaps less pronounced than it is on others and are getting more of those set volts to the GPU so they can hold higher clocks.
It is what it is. I dont think that whopping .03v is going to net you anything however.Perhaps it might be a good idea for MSI to encode something like user set LLC into Afterburner? (having said that on my card AB does not seem to work at all)
Fixed.Your using a multimeter? That is the best way.
PS: don't use Furmark for any length of time, like some people. its ok as a short stability test but any more than that and there is a chance it could damage your card.
Thanks, I'll look into it. If this happens again I'll try those fixes. Seems like Battlefield 3 has some bugs that gave me sort of a "gsod" today. My screen went white but I could get out of it by pressing alt tab, probably BF3 crashed and "stopped responding" so its window became white. But this happens lots of times especially when I alt tab (happened with old card too), man this is one buggy game.I had the same issue. Even at stock clocks I get gsod (grey screen of death) and the only way to completely fix my problem was roll back drivers to RC11. If you google gsod, there's are few of us having the same problem.
