- Oct 13, 2001
these is the new case i have sitting in my room,
CHIEFTEC Full Tower Chasis for P4 and AMD Model DA-01W-420W- AMD Apporved Power Supply Front Accessible: 6 x 5.25", 2 x 3.5", Internal: 6 x 3.5" Power Supply: AMD Approved 420 Watts Power Supply Model# CWT420 ATX 12V for AMD and P4- No Case Fan! Compare to Antec SX1240 and Save Model#: DA
ok what size 80mm fans do i need? or does it matter i see 80x80x25 and then they have 80x80x32 will they all fit? and again i read posts about the "where do i plug the fans up at" posts. i am replacing my volcano with the alpha pal8045, it cannot be plugged into the mb right>? and whats the differnce between version u and t? and what fans do you reccomend?
thanks
thanks
