ok i need some advice
tbirdkiri
nor-cal
wuts the best air coolin heatsink and stuff for oc'in a 950 tbird?
im lookin at:
the volcano 2
cooler master dp5 6i31a
and the global win fpq38
are these good choices?
anything else good?
not really especially now. The Glaciator, SK-6 and Gladiator are all better choices.
ok how much?
do i have to special order it?
who makes it?
and how much will i be able to oc too?
The Millenium Glaciator and Thermal right SK-6 are the two best, around $45 each w/0 S&H. If you are planning to upgrade to a newer hsf, consider them. The OCZ Gladiator is around $20 and would do a great job on that 950. I don't know how high they oc that Tbird too, but certainly a lot higher than those that you listed. The Gladiator is also known as the SVC Golden Gate and you can find a link for it in the cyberdeals section. The glaciator can be found at www.pcnut.com and the SK-6 at www.2cooltek.com.
