- Jun 13, 2004
- Grand Rapids, MI
I have read the sticky's and been hanging around for a few months now soaking up as much info as I can and here is what I have came up with. I plan on installing this on my next rig which I will purchase at the same time. It will be a socket 939 FX-53 system. Here is what I was thinking as I will want to push this rig as far as I can on water.
All 1/2 fittings
OK I think this is the Final Revision. After learning how to read a graph properly I realized that the DD pump looks very good besides the fact it puts a little more heat into the system than the Swifty it lokks great.
CPU Waterblock- Swiftech MCW6002-64
GPU Waterblock- Swiftech MCW50 GPU Cooler
Heater Core- The Double Heater Core from DD with Shroud
Pump- Danger Den DD12V-D4 pump
Tubing- Tygon Tubing 1/2" ID 3/4" OD
2 Fans- Evercool Chrome 120mm Fan 80 CFM 2000 RPM 30Db
Couple things yet. I wanted to go with the Cascade CPU waterblock as it seems to be the best out but it also seems impossible to get.
I also am not sure if I should go with a T line to Bleed/Fill. Will a Reservoir kill the performance of the system that much if any at all? I like the looks of them but don't want to use it if it degrades the performance. Also is Water Wetter the absolute best product to use? I know it stains but does it perform the best at dissipating the heat?
Thanks in advance and I look forward to your input.
All 1/2 fittings
