Ok next ?. What is best HSF 4 a K6 2-500 @ 560?
Get an Alpha PAL6035 . That otta do the best job. And then when you decide to upgrade to a different CPU (Tbird, Duron, P3, whatever), the heatsink will still be usable.
Put a fop 32-1 on it, should be enough cooling and is quiet. only like $18
CoolerChips.com you can always put a delta on it and turn it into a fop 38 in the future.
If you go with the Alpha, spend the extra and get a delta fan on it. It will help when you upgrade to a T-bird.
www.3dfxcool.com
