ok now locating inside
ToTalXS
Smack dab in the center of a non-DSL world.
ok Im going to try and include a drawing of my case layout...bassically I need to know if mounting the rez and pump in the upper half of the case would be better than mounting it on the bottom...my theory is that you have to pump all the water uphill if its in the bottom but if its mounted above the cpu it wont be so bad....just a thought.....Im only goin to be using a cpu wb cause I havent enough cash to buy one for the video or chipset yet.........also if small enough radiator was located I could mount it just above the powersupply and then everything will be very close to each other.......but maybe that will reduce air flow.....through the radiator that is........hmmmmmm...just a few Ideas
my only reservation about having the reservoir above the mobo is that the res might spring a leak, then it's "by by 'puter." with the res below the electronics, you have less chance of a small leak causing a big problem.
Other than that, it sounds like a fine idea.
