- Jan 22, 2013
- Michigan
I haven't been on here in probably a few years, but just did a nice budget build comp, got a Biostar z87 MB, supports up to 32gb ram, 1150 socket, with a 3.2 ghz duo core, 8 gb ram, (2x4gb) Radeon 7770 2gb GHZ edition, I think, know it's 2gb of ddr5 on the card, 500 gb SSD. Middle Earth: Shadow of Mordor, I noticed how great it could look, but was somewhat laggy, and had a fair amount of settings turned down. I can get a 2nd 7770 2GB for about $70 and run crossfire, but I'm guessing that what I really need is a better cpu? I know GPU does a very vast majority of the graphics, but some of it also relies on the CPU. I'm thinking that what I really need to do is get a quad core, but, well, they aren't cheap... I wish I could check the classifieds here, but it says private, and I can't see anything. Also wondering if getting a sound card is worth it, as in does it eat much ram? The on-board produces really nice sound, just don't know if it drains performance that way, and what you would recommend rather cheap, all in all this build comes in under $450, counting the 640gb Sata I bought for my old computer before deciding to build a new one from scratch. Oh and the DVD burner is stolen from my last build also... Extremely happy with what I have for what I paid, however I know it could be soooo much better, I just need to know the direction to go next. I remember somewhere there was sort of a stress test windows had on it, that would tell you your weak link, but that very well may have been on XP, if not I have no clue what it was, or where either lol. Know that in the control panel there is the performance information tool, which says my primary hard drive is my draw back, being rated 5.9 when everything else is in the mid 7's, think that's because it's not only testing the SSD, but also the HDD.
