- Feb 12, 2001
- Fayetteville, AR
Well i have the Millenium Glaciator 1, with the stock fan. IT is lapped pretty good using AS3. Well at 1330 default speed, i get liek 37 idle adn 41c load, and at 1578 which i run at now 1.825vcore i get like 41c idle and 46c load. Not AWESOME temps but not bad by any means.
I will probably upgrade teh 60mm fan to a better 60 mm one, i found a Thermaltake 60mm that is less db adn more cfm but the problem is that when i put my had around the Glaciator it feels as if the fan is blowing down toward teh HS, i am 9% sure that it is as i feel NO air coming of the top of the fan out the grille, and alot of air being pushed out the sides.
Can anyone verify if the Glaciator fan blows in or sucks out. And which way is better, meaning should i get a fan that sucks out of the HS instaead of blowing in.
