I have an older set of parts I used for cooling a previous`computer.
It used an Eheim 1250 120 volt pump.
I had a 6"x6"X2" radiator that was called the "Big Momma." It was based on an older auto heater core. It was considered a solid performer way back when.
There are two 120 mm fans within a shroud, one pushing, one pulling air through the core. Each sits maybe two inches from the radiator core. These are 120 volt fans with a fan controller that allows me to control the speed and noise of the fans.
Finally, I have an older copper CPU block. I honestly do not know the brand.
It is about 2"x2" and perhaps a half-inch thick. It has two 1/4 inch (ID) fittings along the side. I've looked on the Internet to find out the maker and model number, but no luck. I'm sure it is 9 or 10 years old.
I used 3/8 inch (ID) silicone based rubber hose. This system cooled my older Pentium 3 system well. All these parts fit in a box. My PC case sits on the box. The hoses and waterblock were threaded through holes in the rear of the computer case.
I already have all these things. No investment is needed.
I've built a new Intel Core I5 2500K 3.4 Ghz. based system. (I was able to obtain an Engineering Sample with a D1 sampling.) The motherboard is the Asus P8P67 LE Rev.3. (I know, Pro would have been better.) I have 16 Gigabytes of Corsair Vengeance 1600 RAM. Just using the stock Intel cooler for now. Corsair 700 watt PSU. Radeon HD 5570 budget video card. It does fine for my needs. New $50 mid-tower case.
I've sunk my money money into the system parts, including a 27" monitor. I'm not trying to squeeze every last Hertz out of the system, though an overclock around 4.8 Ghz, would be nice. These I5 2500K's seem to put out even less heat than the earlier Pentium 3 and 4 processors.
Some folks are overclocking this kind of setup using nothing but better air coolers. I feel that even with my dated watercooling setup I should be able to achieve better performance than most air coolers.
I know that there have been big improvements in pumps, radiators, and particularly water blocks. But these will require an investment of something North of $150 to get some of the latest and greatest.
I figure that I can update the water cooling parts as funds become available.
Hey, I'm a retired old dude. Cut me a break.
What do you folks think? Am I wasting my time with my older watercooling parts? It's kind of fun to tinker with it.
BachOn
BachOn
