- Jan 31, 2002
- NJ
OMG!!!! I FINALLY DID IT!!!!!...I UNLOCKED MY TBIRD AND DID AN O/C FROM 800mhz TO 1000mhz!!!
WHEW I had to get that out and tell everyone here THANK YOU!!!!
current temp---idle 34-36 (sorta fluctuates[sp?])
under load----40C
weird thing was that my temp monitor when it was locked read temps a lot higher than what it is now being unlocked...strange?
also...it monitors all the other power lines (ie...12V -12v 3.3 and Vcore) I gives a warning that the 12V line is out of reading ability....it says it because every once-and-a-while it goes to 11.9V...is this normal?
Anyways THANK YOU EVERONE!!!!!
Spec
EDIT: I will try to get more out of it
under load----40C
Spec
