- Jul 31, 2004
You need the adapter to put between the fan's molex and power output on the controller.
If you have a pin removal tool and wire strippers and maybe some electrical tape, instead of buying the adapter(s) you could just move the power lines (12V and ground, yellow and black) from the molex into the RPM line from the fan, since it already has the 3-pin connector. The yellow 12V molex wire should go where you see the red wire on the 3-pin cable, and the black with the black.
