That's hilarious, I had my hard drive die last night, somehow while installing XP on the new SATA drive I got, it got assigned letter E: so now my Windows installation is on E:i know this is dumb i was tierd and installing in the middle of the night.
is there a easy way to get it to c: or do i have to reinstall?
That is a very good way to corrupt your install quickly. There is no easy way around it, the effort it takes to change the drive letter far surpasses a quick reinstallHit Windows Key+R, type regedit hit enter.
Go to HKEY LOCAL MACHINE > SOFTWARE > MICROSOFT > WINDOWS
Change any of the C: installation paths to drive G:
You have to unplug all ATA drives other than the primary master HDD and CD drive, reformat and try again. Sorry.
That means you must unplug your secondary HDD and all other HDDs! Must install with one HDD only!
This article describes how to change the system or boot drive letter in Windows. For the most part, this is not recommended, especially if the drive letter is the same as when Windows was installed. The only time that you may want to do this is when the drive letters get changed without any user intervention. This may happen when you break a mirror volume or there is a drive configuration change. This should be a rare occurrence and you should change the drive letters back to match the initial installation.
No, in the bios you have to set the priority of the HDD you want as C:
