- Jun 29, 2001
- Normal,. IL
Well, I have a couple of my new heat sinks in and I have started testing. I got my SK6 with ystech fan, and my Millennium Glaciator; the new Swiftech SCX-370 is on backorder (as well as my AS2 that’s supposed to come with it). Let me just say, that I am impressed so far, very impressed. After the quick demise of my Delta on my Globalwin WBK38, I have had a regular 80mm strapped to the top of it. Although, like that, I was unable to run at a full 1.4GHz due to heat. The system would hang on loading win2k, so I had to run 1.2GHz and only achieved mild temps. 38Cidle, 45C under normal load, and 53C while playing Tribes2.
I hooked up my SK6 yesterday and got decent results. 34C idle, 41C under normal load, and ~49C under Tribes 2.
Today I hooked up my Glaciator (which came with some AS2), and got surprising results. During boot, is when I end up with the most load. Usually around 48C on just about ever HSF besides this one. I barely made 40C. Wow! Idle temp is ~36C, maxed out at 49.4C on the 10th run of Sandra’s Burn-in running just CPU and Multimedia benchmarks. Under full load from Tribes 2 I only hit ~47C. I’m happy. Lets just see if the new fangled Swiftech can match. Props to Millennium.
Testing was done with my DigiDoc5, with a termisistor trimmed and touching the die under the HSF.
Ill write up a little more specific report once they are all in.
