onboard sound vs sound card
Robbiem01
I feel stupid asking this but how much better is actully having a sound card rather then using onboard sound? what are the advantages? Is it worth $40+ to get the better sound even though its just gonna be muffled by my 80cfm jet engine?
<edit> woops typo i ment 80mm 80cfm delta fan (he he)
lonewolf1983
perth, Australia
onboard sound is ok if your not playing much music or gaming
and will also eat cpu cycles (not much tho)
personally i ran onboard for a year with no hassles
But i so love the quality out of my SB live
funnyperson1
Senior Member
unless you have speakers that cost upwards of 50$ youre not going to see a difference also depends on what onboard sound you have...ive found the newest C-media one to be just as good as my Sound;blaster PCI 512 (hey another sound card :))
dreamtfk
Orlando FL
Well I have a Asus A7V266-E and from what I've heard the OB sound is exceptional of course I use my SB Live...so I wouldnt know.
TheWIZ:Part2
Taxachusetts
Actually onboard sound can actually be equal to or superior to add in sound cards. The C-Media chip on my motherboard sounds much better than the XP theater and is easily equal to a Santa Cruz or SB LIVE! card. It all depends what you have. AC97 blows though and so do some older onboard solutions.
JimmyG
Michigan
I have used AC97, C-media, and SB live. To me, there was not much difference.
But, that's just me!
Silver
Senior Citizen (aka old fart)
Dallas, Georgia
I have no problem with the onboard sound but then I may be tone deaf. I use ear muffs or whatever they are called as the computer is in the living room and by using these I get what I consider to be great sound, as loud as I want and I don't bother a soul.
