- Oct 10, 2002
- England
i have a msi 6378 mobo with onboard video, i cant disable the video but is it still posible to install my PCI hercules 3d prophet 9000 on my computer.
splash back said:i have a msi 6378 mobo with onboard video, i cant disable the video but is it still posible to install my PCI hercules 3d prophet 9000 on my computer.![]()
splash back said:yes i have installed the hercules and no video then again this is wot hapened with the onboard1 and if i was to disable the onboard video in device manager and the hercules didnt work would i be able to get it to work again?
Pinky said:
Although I have my doubts uninstalling it in device manager will work (since the onboard video will be detected on next bootup), a cmos reset should allow the onboard to work again...
mbentley said:
you don't want to uninstall it, just disable it. and yes if it doesn't work you can just boot into safe mode to enable the onboard video again.
Pinky said:
Oooohh... sneaky devil you!!![]()
mbentley said:
disable the device in device manager. it will probably ask you to restart. when it does, shut your computer off and then install the video card. should work fine. that's just what i did with an older mobo i had that would not disable the 1 mb oboard video... let me tell you, 1 mb video is ridiculous compared to a gf4 ti 4400![]()
Pinky said:Nope, the onboard will always override any peripheral card you add unless you CAN disable it.
