I picked up a NF7-S from a forum member last week and got all excited thinking I would be able to get a better (even if slightly) OC by upgrading from my A7N8X-X. On that board I could usually run my 2500m+ at 12.5x200 with 1.825v which is the board's max. I felt that was holding me back from maybe a multi bump or any increase above 200fsb. Apparently I was wrong.
The only thing that has changed is I can boot with settings higher than 12.5x200. It's not stable by prime95 standards, failing on the first test. I bump the cpu voltage, I loosen my ram timings, bump up ram voltage a little, still left with nothing over 2.5ghz.
I'm using Tictac's d23 subzero 4227 BIOS with the hardware I have in my sig. Any other suggestions? or is this just this proc's top line?
