One stupid question
J0HN
How can I get the CPU temp in WinXp?? :eek:
I got CoolMon running, but no clue...
J
J0HN
Thanks for the reply,
I got mbm5 installed, and one of the sensor is 126c!!
After I intalled Asus Probe 2, I delete mbm5.
Now, I don't know should I trust Asus Probe 2. In BIOS, MB temp is 36c and CPU is 54c; In Asus Probe 2, MB is 36c and CPU is 38c.
Using my finger, the HS should over 38c, it is way warmer than my temp (37c, I am a human :D)
So, what should I do??
N
nerdlogic
Guest
You must have had MBM set to the wrong sensor...(I don't know what sensor you should have it set to for your motherboard)
Try SpeedFan and see how that works for you.
