OneClick uninstaller (single and dually)
madman_sam81
Sacramento, CA
I had to make a quick and easy little uninstaller for Wedo's OneClick service installer and thought I'd share it with you guys. Nothing fancy about it; it just stops and deletes the service(s), then deletes the FAH directory (C:/Program Files/FAH) completely.
This only works if you used Wedo's OneClick installer. The service name(s) and the directory will more than likely be different than those created by other installers.
Anyways, here they are:
OneClick Uninstaller
OneClick-Dually Uninstaller
Edited: Sorry Wedo! I was in a rush?
Nice work madman, just one question though. Who is this Wido that you speak of? ;)
because often to fix folding you have to manually delete entries and try it all over, these should make that much easier :D. also as veryhumid said that way we can try the different installers with much less pain :p
Yes, does anybody have a copy? I could mirror it from my site, t'would be no problem, I just need a copy.
One of the duallie and one for single instance.
-Sam
No one has a copy of either of these? Seriously, I'll mirror it.
Please!? I need it as well!
-Sam
This thread is pretty old. madman_sam81 hasn't been on since August. People get busy with life so I'm guessing we can pick the program back up and host it. I think the website was put on hiatus and the domain was bought by someone else. I'll pm Wedo and see if I can get a copy so we can get this back up.
Right on!
-Sam
