I hope this is the one you were talking about
Overclockers Forums > Overclocking > Folding@Home > Update on Folding Linux - testers required soon!
PenguinFreak
Rank:
Site for folding linux - 'overfoldix' is:
http://myweb.tiscali.co.uk/nelson27
Currently just a quick Q&A
I have emailed the creator of the base system and have permission. I should have something usable by mid march. I will need volunteers to test it - it is unlikely that it will work first time, but will probably be usable within a few weeks.
The system requirements:
A PC (duh! ):
Any CPU that will finish a WU in 9 days
About 16MB RAM minimum - 32MB strongly recomended.
CDROM drive - capable of booting off a CD
One of the following network cards (or compatible):
SMC ultra, 3Com 3c509 and 3c590, VIA-Rhine, Intel EtherExpress pro 100,
AMD PCnet32, RealTek 8139 (not all revisions), DEC Tulip and NE2000.
You will also need a connection to a network or direct net connection. Support for dial up internet will follow later. F@H should take care of the proxy business.
PF
__________________
Using Linux since 4th Jun2001!
Athlon Thunderbird1100 @1144
Winchip 180 @ 200
AMD K6-2-250 @ 333
"The nice thing about standards is that there is so many of them to choose from" - Andrew S Tanenbaum
Report this post to a moderator | IP: Logged
03-04-2002 02:18 PM
KaHNZa
Rank:
Sounds interesting. But I would need to install Linux on a machine. Maybe I'll make that a weekend project. I've always wanted to delve deeper into Linux.
__________________
If you have money, upgrade your computer!
03-04-2002 02:24 PM
TT120
Rank:
Senior Member
I'm in as I already have Folding running on my Linux box (thanks to you) You may have to help me a bit since I'm a total Linux newb.
__________________
Lanparty.
03-04-2002 02:35 PM
Spike Spiegel
Rank:
quote:
the whole point of this is that you don't need linux installed...penguin is building a stand alone distrobution whose only duty will be to fold 24/7 with as little hardware as possible (running off of ram rather than hard disk). so if you have an old box that you wouldn't mind wiping out to try out "overfoldix" on, it'd be a great help to him!
jeff
__________________
-Redhat 7.2 with Ximian Gnome!!!
-Abit KT7A, AMD Athlon T'Bird 1200 @ 1200 (grrr), 512 mb Crucial
03-04-2002 03:32 PM
kendan
Rank:
I am in I just have one question. will you be able to boot any windows computer off of the disk? Ex. My brothers p4 1.4 I change bios to boot cd first and boot the Folding linux CD. It folds using linux. Then I turn it off and boot from the hardrive. Will it be back to normal windows? Or will there be any problems? Thanks.
__________________
AMD TB 1.4@1491 and climbing
KG7-Raid
Glaciator2 (45 @ load)
Win2k
2 x 40gig Ibm Raid 1
SB Live Plat. 5.1
Gainward GForce 2 mx400
Plextor 24/10/40
Toshiba DVD
Folding@Home Team Leader.
Avatar by: Über~PhLuBB
03-04-2002 03:41 PM
Spike Spiegel
Rank:
i was wondering the same thing...i would definitely be up for testing if i didn't have to disable my hdd or uninstall my current installation.
jeff
__________________
03-04-2002 06:22 PM
res0r9lm
Rank:
I have a netgear 311 network card is it going to be compatable
A PC (duh! ):
__________________
Tbird 1400 266 AYHJA
[email protected]
shuttle AK31 rev 3.1 10.5x152
Crucial 256mb ddr 2100
swiftech mcxc 370
fong kia fk-320
40c@100% Load
duron 800 AMCAK@958
ASUS A7v rev. 1.02
swiftech mc 462 38c@100% Load
Crucial 256mb sdram
folding as Ralph_Kitchens
stanford's stats page
statsman
Den's stat page
fah 2.19.exe
03-04-2002 06:37 PM
clboertien
Rank:
so i'm guessin onboard lan is out?
__________________
Cheers
Rigs: Athlon 1GHz Tbird
Beer - the cause of, and solution to, all of lifes problems.
<------- Avatar by Über~PhLuBB
Keychains
- AMD Athlon XP 1700+
- 256MB Crucial PC2100 Cas2.5
03-04-2002 08:38 PM
Kentucky Fried Bird
Rank:
overfoldix sounds good. i can devote at least one machine to testing (K6-166).
__________________
Gigabyte GA-7DXR, Athlon 1.0GHz AXIA-Y 266FSB @ 1496MHz [136x11] 1.85V, 256MB PC2400 Corsair DDR, Radeon AIW, Volcano 5 w/Delta black label [max 49C Folding], 2 x 40GB 7200rpm IBM, Enermax 431W PSU, Pioneer 16x DVD, hp 10x CDRW
