_jubei_
Disabled
- Mar 12, 2001
- BROOKLYN, NY
what is the Difference between those two ??
When I ran UT in Direct 3D on my system, after ~20 minutes of online play my PC crushes.. But when I play UT in Open GL everything seems to work fine. No crushing !!. I was wondering what is the Difference between those 2 .. Also what is the BEST setting for Direct 3D, and Open GL options for the Geforce 2 family video cards....
Also How much MB of system memory do you use fo textures in PCI mode ??? Direct 3d / Open GL
Those are mine
Direct 3D---> Use up to 63 MB of system memory for textures in PCI mode
Open GL ---> Use up to 5MB of system memory for textures in PCI mode.....
Direct 3D crushes
Open GL does NOT.....
HMMMMMMMMMMMM ..................
Those are mine
Direct 3D crushes
