@Nebulous: Could you try the latest version 0.1.2-beta? I have fixed Core i7 temp reading, Nvidia GPU enumeration and added support for the Fintek F71882 chip (which your board uses as far as I know). Fintek detection is still experimental, since I don't have any hardware here.
About HWMonitor, Everest: The GUI is similar to these application, but the project is otherwise unrelated.
Neb,
Did you turn it on?
Maybe it doesn't read Klingon.
@Nebulous: Just to be sure: You tested the new version 0.1.2.0 Beta as well? And you get the same results as in your first test with version 0.1.1.0 Beta? I add new version more on a daily basis right now, so this could cause some confusion.
@I.M.O.G.: Creating sig images from the data, or reporting it in other ways is no problem technically. The current GUI and output features are bit minimalistic right now. So once the hardware detection and reading part is more complete I will be adding more output and reporting options. What do you mean by "under the overclockers.com name"? I think it does not make much sense to brand the official project releases with overclockers.com (or at least I don't see how). But adding a reporting feature where you can report specific data to the overclockers.com url should be no problem. But GUI wise it needs to be done in a way that allows reporting for other sites as well (if they want it). In any case, building a special release for overclockers.com will always be an option (as it is open source).
mmoeller;6383345 said:@Brolloks: What Hardware do you use (GPU, MB, HDD)? Did you enable HDD sensors in options?
@Nebulous: Thank you very much for your feedback. It will help me to remove a problem with the Nvidia API. And yes, if you need a stable product today using hwmonitor is (by far) the better choice.
@AmbientFiction: It should run on AMD 9h as well, just not report any core temps (but this will be added soonish anyway). Can you post the file OpenHardwareMonitor.Crash.txt from the folder where the exe is?
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at OpenHardwareMonitor.Hardware.SMBIOS.SMBIOSGroup.BIOSInformation..ctor(Byte type, UInt16 handle, Byte[] data, String[] strings)
at OpenHardwareMonitor.Hardware.SMBIOS.SMBIOSGroup..ctor()
at OpenHardwareMonitor.GUI.MainForm..ctor()
at OpenHardwareMonitor.Program.Main()
