:opinions wanted:
mumrah
I just bought all the stuff for my WC goodness. Here's what i have so far:
VIA Aqua 1300
Maze 3-1 water block
Swiftech dual 12cm rad
two vantec stealth 120mm fans
Figi water bottle res
3/8" tubing
I'm putting the pump under the hdd bay (i've got an Antec SOHO case) and i'm cutting a blowhole above the 5" bay area for the rad. I need to build a shroud for my fans (ideas welcome). I'm going to mount the res outside about an inch away from the two 80mm exhaust fans (for less turbulance). I've got the inlet and outlet on the res at the bottom (bottle is upside down) to minimize bubblage.
Flow: Pump - water block - rad - res - pump
i've got a dually, but no second cpu right now, eventually i'll be cooling 2nd cpu, gpu, and NB.
what are some tricks of the trade you all can offer? silencing and such..
?:eek:¿
oh yea, and how am should i get that thick *** power chord from the pump to the wall? can i cut it and feed it through and reconnect it?
