J
jb
Guest
Hi all I was wondering if there was any special benefit to having positive or negative air pressure in my case.
I was thinking if I had my case all sealed up except fo the fan holes and I had extra cfm's pumping in I could cut out a blow hole on the top of the case over the cd-rom's. Maybe that would work better than having just equal air flowing through the case plus I could possibly cool down the HDD and cd-rom's without buying one of these special fans (save room and money).
Then I was thinking if I had extra cfm's blowing out the vents in the bottom of the case would suck in fresh air. I don't know maybe that would also would work better that just the stata quo equal air flow.
If you have any thought's post and pls post if you've tryed some or all of those idea's.
