Orbs Rule
dbenne00
I have always used Orbs - mainly because I use a sloket adapter and I can't afford to lose a memory slot.
My Golden Orb ran my C566@850/1.8v for a year or so, then I upgraded to a PIII750@1000/1.8v and got a Mini Copper Orb for it. Both work great, and I've never damaged a CPU with one (and 100's of 1000's of other people haven't, either).
I did try getting more out of my C850 at one point by trying out a FOP38, but the bottom wasn't nearly as flat as my GORB, and it actually performed worse. So I stuck with my trusty Orb.
Ooooops - this was supposed to be a reply under "SuperORBS BAD!!!", not a new topic.
Sorry, I clicked the wrong button - But that's what happens when you're trying to do this from work without anyone seeing :).
I have chipped a slot 600, but i still use my GORB on my new tbird 750, and it works great-not a high end chip and its running default speeds, but its still enough to cool a tibird 750@900 -cause the guy si got it from had that setup -the colplate and the GORB are properly lapped using crap thermal grease but it does the job
Some have luck with the Orbs, some haven't. For the price, I think they are ok, and most of them can handle moderate overclocking.
However, a Gorb cooled my P3-700@945 to about 32c heavy load. The Pep66 cools the same cpu @1050 to 30c running folding.
Go figure.
Allan Nielsen (May 29, 2001 12:47 p.m.):
Go figure.
the orbs aren't bad, especially for older cpus that produce less heat. But with the newer ones, they are starting to show their age. But like Allen said, they have a great price/performance ratio. Although I think the Fop32-1 is still the best price performance wise, the orbs aren't horrible. A lot of the cracked cpus with orbs come from people using the wrong orb on the wrong socket, DOH!!!!.
